WF-9865 Converter/Charger
HomerBB
Jan 4, 2009
3,941
2,682
273
69
Rogers, Ar
I found this 65AMP converter/charger for RVs at a flea market brand new in the box for $20.00.
I looked online for the value of this item. Amazon had three new sources that represented the retail range for it:
I am going to see how it does as a Power Supply. I do use a battery to run a mobile amp, so filtering through a battery if necessary is already in place.
It is a three stage Switching unit that responds to the load need sensed, it can be a fast charge unit, or a trickle maintainer as needed. It will respond to loads for supplying 13.8 volts DC as well.
Anyone know much about these?
  • @ Geoexplorer69:
  • @ Geoexplorer69:
