Did you take your meds this morning?
Why am i hearing 3-5 stations at once through 20m-17m on WFM? i also hear it up in the 200mhz-400mhz... only on WFM.
p.s its music and talk radios. not picking it up on AM or FM or even SSB.
What radio?
Do you have a commercial AM or FM station close to you?
Poor front end receiver design?
Ic-7000 was looking for conditions.
Never had it happen in my mobile stereo.
Sent from Outerspace, on the DarkSide of X.
I thought that the Wide FM mode could only be enabled on the 76-108 MHz band.
In any event the cause is strong front end overload from commercial FM or television broadcast stations,most likely FM stations.That WFM mode opens up the frontend to about 150-200 KHz wide rather than the normal 3-5 KHz for SSB and AM or 15 KHz for normal FM. that lets LOTS of crap in and messes with the frontend. WFM also uses a different second IF frequency as well that may be part of the problem
