Hello all
Newbie here to the site but have been around the Cb radio since my first 23 channel radio was purchased for me in 1977 when I was 13 I use a Cb daily in my work semi running barefoot I’m now 58 and finally got a base hooked up I run a cobra 2000 gtl currently swings to about 14 watts on am and low 20s on ssb I’m not sure what the dead key is set at but I’m running a 150 typhoon mobile amp powered by a pyramid 35 amp power supply Antron 99 antenna and 150ft RG 213 coax swr no more than 1.2 across band I get good reports both am and ssb I really like the Texas Star amps. I was looking at the 350hd my question is would this amp give me a more noticeable difference than the 150 I’m using? If so would the pyramid 35 amp power supply be enough to run the 350 hd? Would the dead key on the cobra 2000 need to be set low? Just looking for clean crisp noticeable results. Or should I go higher like 500 ? Opinions advice suggestions are welcome THANKS IN ADVANCE!!
