What base antenna to get? I have the A99 now...
The Vector 4000 is an awesome vertical as is the Maco v5/8 and the make a version of that with a higher output limit the v5000.
I have a Wolf .64 just sitting in my garage looking for a good home and an Imax 2000 but the shipping would be a bit.
if you live in a area that get's much ice build up on antennas in the winter or high winds from big storms the vector 4000 may not be durable enough . you can home-brew one strong enough though . if money is tight a $60 workman 58 from palco will fill the bill .
http://www.palcoelectronics.com/p1005081.aspx
if you got deeper pockets you need to lighten or need a lot of bandwidth the gainmaster is getting lots of good comments .
The three best verticals out there -IMO- at this time are:
*Sirio Vector 4000 @ $150
*Sirio Gain-Master @ $185
*Imax 2000 @ $100
In that order . . .
rob theres 4 and you forgot #2 and mixed up 1 and 3. #2 is the the penetrater for $150 but if your not runing more then 500 watts then #1 is the gainmaster. its the best for performance and dependability. it has awesome ears. better then my old i10k especially with european dx
1] gainmaster
2] penetrater
3] vector
4] imax
9] maco
50] a99:bdh:
    535A has left the room.
  • @ AmericanEagle575:
