@trees: You mentioned a Western Star, so I will assume you to be a trucker. So am I.
This project seems interesting as something to do, and a learning experience, but I don't see any further benefit. I think that you would be better off with a standard 4' fiberglass whip, because that will be more flexible than the half aluminum, half fiberglass hybrid, that you propose.
Flexibility is a good thing. If you smack something with your proposed antenna, it's more likely to break, than an antenna that's all fiberglass.
Myself, while I really like the Firestiks, I'm done with fiberglass. Had to replace too many.
Well, that's not entirely true. I assembled a vertical dipole, and use a Wilson 1/4 wave whip as the bottom half, but it's protected by the mirror bracket.
In any case, your hybrid antenna seems like an awful lot of trouble, and after putting all that time and effort into getting it right, it's going to be a hell of a lot more frustrating if (and I think, WHEN) it breaks, as opposed to one that you just bought and installed in its originally manufactured condition.
Although, a spring in between the shaft and fiberglass.... Meh.... Still seems more trouble than it's worth, to me.
