MY Farm
10 meter antenna: Homebrew 5/8th's ground plane/36 ft up to radials...
The "Backfire Array' consists of 4) 40 meter dipoles basically in a inverted V type set-up...the south ends are about 25 ft off the ground...the north ends are only about 20 ft off the ground.
I am going to try and post a drawing to give you an idea of how it is hooked together.
The set-up is a pair of "Lazy H's" laying Horizontal and feed 180 degrees out of phase.
I have a double "L" tuning network...
I have used it on 80m/40m/10m and it really cranks on 17m. I have got really good reports even on 80m in the 500 mile range.
40m I can work anywhere...Work the Aussie's pretty well from Indiana.
17m: If I hear I can work them...S. America/Africa have been worked as well as Europe
10m: Here it is has both Horizontal and Vertical signals...really weird but chatting local inside 100+ miles, the ground plane is better. When the band is open to the west the array can be stronger at times.
Hopefully next spring I can get my new freestanding 52+ft tower up and I have a 4 element 20/15/10 meter Yagi plus a 40 meter dipole kit all on a 18ft boom. I also have a 12/17 meter 3 element Yagi and a 30 meter dipole kit to go up on 45 ft of Rohn/25G.
I hope for an early spring!!!
