The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
What's a good SWR meter for 2 meters/70 centimeters?
I use the Diamond SX-1000 and it works great. It has two sensors for two inputs on the back. One is good for 1.8-160MHz while the other is good for 70cm, 800-900 MHz, and 1.2 GHz, pretty much good for DC-daylight. It handles 200 watts on all bands.
My MFJ uhf/vhf meter always shows low swr. As a matter of fact I discovered it shows low swr even with no antenna connected! Power function seems ok though. I would avoid the MFJ meters.
I like my Yaesu YS-500, and may be tempted to part with it near the end of
this month. The cost was under $150.00, and does not require separate slugs
as would the more expensive SWR meters by Bird and others. It is probably
not as durable, but for occasional use, it works fine.
73 de KB0MNM- Jon - jlivingston10@cox.net
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
