What to you want to use the antenna for? Local? DX?
If DX is your goal I would stick with a horizontal wire antenna of some sort, such as a center fed dipole. They tend to be pretty durable, of only because they are both thin (aka aerodynamic) and have at least three tie off points for support. Careful if you mount the wire between two trees, if the trees sway apart from each other the wire will break. That being said, it is only a wire, so not to expensive to replace...
For local... You can get one of those extra durable 5/8 wavelength antennas like the I-10k, although they usually say either 100 mph or 100+ mph winds. Also, make sure the mast is also strong enough to support the winds you are talking about. I've seen incidents where the mast was the failure point, not the antenna. In those kinds of winds the antenna acts like a big lever hanging out putting essentially twisting forces onto the mast.
Someone above mentioned a Vector 4k. If you take that option plan on doing a ton of strengthening as that model of antenna is not known for being the most stout antenna on the market, although several people built their own stronger versions. I also don't know that I wouldn't trust a fiberglass antenna in those cases, even one as good as a Gainmaster. 140 mph winds is really beyond what most people have experienced, and if there is sand in (he did mention high desert area) it will effectively sandblast everything. I doubt any fiberglass antenna will last long in those conditions...
Aside from the I-10K esk antennas my best recommendation is to build one yourself. It is the only way you can ensure the durability you need. I am thinking along the line of a double thickness inch diameter aluminum tube with a second tube that runs the length of the antenna inside the outer double walled tubing, and using super alloy 5 to effectively weld the tubes together, making the outer tubes effectively a single piece. Not a cheap solution, but one that will last no matter the conditions. After double tubing for the radials, this would also not be a particularly light antenna, so it would also need a mast that can support both the comboned weight and the wind load.
Perhaps, if that is just to much for you, get a hub that will let you make a few 102" stainless steel whips into a Starduster style antenna. Those stainless steel whips are about as durable as antennas come. Something like
this.
I hope you get something figured out, and no matter what it is, let us know about it and how well it survives...
The DB
