I have used a homemade 2 ele quad for a few years now, fed with a commercial 1:1 balun and a 1/4 wave of 75 ohm coax, which has worked very well. I wanted a little more gain, so last week I extended the boom and added a dipole for a director, so now I have a Quagi (cute name huh). Problem being now I have a 2:1 swr, a friend of mine suggested a clemens match, which I built, but found it gave me a very narrow bandwidth, in the region of 200kHz between 1.5:1 swr points, which is not good enough (for me anyway). Maybe I did something wrong or didn't build the match correctly, I'm not sure. I could just make a gamma match, but I'd prefer a balanced matching circuit. A T-match is supposed to be very hard to tune, so not really keen on that either.
Looking around the net I've stumbled accross the hairpin match, seeing as I have a 1:1 balun already on the antenna, this seems like the ideal solution, although I've also read that this match will reduce the gain of the antenna (allthough only by a few tenths of a dB). I've also read that to use the hairpin I would have to reduce the length of the driven element by 3%, which I'm not keen on doing incase I ever want to go back to using the antenna as a 2 ele quad. The main problem is all the infomation I can find is all relating to a yagi antenna, and my driven element is a quad loop, so I'm not 100% sure that the calculations/measurements given for a yagi will work for me.
My question is, all these different matching systems seem to have different pro's and con's, but from your experience (that I know you guys have a lot of) which would be the best match to use on my antenna? "Best" would mean: cleanest/most balanced radiation pattern, lowest loss in the matching circuit, and also ease of construction.
Remember my driven element is a quad loop, supported by a non-conductive spreader, and I already have the 1:1 balun on there. I thought I'd ask you guys before I take the plunge and buy the materials to make the hairpin match.
Thanks in advance...
