The hole is already drilled on my car, so the trunk lid is where it will be hard mounted. Height is a concern, so here are my two choices to pair with a 2970N2...
Wilson 5000
Predator 10k single coil w/9 inch shaft
Yes, I know that a roof mount would be better, but this is not an option for me. Yes, I know that the 10k would be better with a taller shaft, but again this is as high as I can go.
So, I'm looking for opinions as to which setup (between the two above) would tune up better for overall performance. Which would you choose?
Thanks!
Wilson 5000
Thanks!
