Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
The M-2057 is the "sweep tube" with the highest dissipation level. No other sweep tube exceeds its rating and its only equal is the 8908 version in an octal base. The two tubes are identical except the M-2057 uses the 12 pin Compactron base.
The 6MJ6 has the same plate dissipation as a 6LQ6, but has sturdier plate construction. The 6MJ6 is what you could call an "industrial grade" 6LQ6. But both are 30W plate dissipation per tube.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
