what "frequency" are you refering to?
hookedon6, in this case I suggest you look at the graph represented by the data from my SWR meter, and my analyzer, to see the low point for SWR noted. Also note in the data fields at the top of the graph, where the analyzer data is recorded, that the impedance within a modest range of resonance (or lowest SWR) did not change as you have suggested. For me it is obvious that the frequency did change somewhat dramatically, from about 27.405 down to about 27.105. IMO, this is the reason Colt45 saw a change in SWR for the system.
Again, I would claim that the SWR measured at the feed point of a reactive antenna, if measure before and after, would remain similar, while showing a change at the TX'er end of the feed line
WON'T, it will appear to change due to transformation of the feed line.
The only real way to change the SWR for an antenna is to make a physical change to the antenna, tuner, or the environment around it. This is also why I recommend to always, when possible, tune at the feed point and at installed height.
lets see,.... you added a "choke coil" @ the feed point in an attempt to uncouple the line from the antenna. obviously that isn't effective. there ARE better methods available to uncouple a feedline.
I did add the choke to check to see if it would help to decouple the feed point from the feed line and it did seem to work in lowering the noise, but I admit that perception can be purely subjective in its determination. Otherwise I noted no other positive responses. I did note the change in resonance as noted above, and had I constructed the choke using the existing feed line instead, I doubt I would have seen the change in frequency.
put the VSWR meter AT the FEEDPOINT (where it belongs) and you will see NO change.
I agree and that is my point in a nutshell.
let me ask you a question,....... has any radio ever been damaged by a "high" VSWR????
ever?
the answer is no,....... because radios don't "see" VSWR, they are not in any way, shape or form affected by VSWR.
VSWR doesn't actually exist,... it's just a math ratio.
the ONLY thing a radio "sees" is impedance.
IMO, your last statement is a typical straw man argument, to use the words never, no way, shape or form does SWR ever affect the operations or the lack, with your transmitter. What about the cut back circuit that attempts to control the power under a high SWR condition?
you really should brush up on Smith Charts and you will find out that the "VSWR circle" is really an elipse.
I thought you said VSWR did not exists, but now it appears on the Smith Chart? That is interesting. Why don't you do a Smith Chart indicating the addition of more feed line to a vertical 1/4 wave antenna that is matched perfectly and one that is not. That should be easy to do, and interesting to see what it is that you see in doing so. I gave you an example of what I see, so how about it?
