For PEP measurement true, but I was measuring RMS. Anyway, I took my scope out from a box, will post measurement in a few minutes.Would be 100% modulation if 25 watt carrier modulating to 100 watts.
Mike
There is a measurement of IC-7610 AM on the scope.
View attachment 33213 View attachment 33214
Looks like almost 100% AM modulation.
Mike
I am able to get 150% positive modulation out of my ftdx1200 from a 15 watt carrier. It only makes 6k wide AM with a mic plugged into the front. Odd that it will do almost 4k on ssb and not make 8k on AM. No modifications except mars and the essb cheat code have been done to the radio.
I'm Not an Expert of what a clean signal looks like on a Scope but that one does NOT look clean from other examples I have seen online?
SIX-SHOOTER
SIX-SHOOTER
Are those examples a single tone or a human voice?
Single Tone I believe & a lot more uniform.That scope picture looks all out of shape like me. LOL Not Pretty & smooth at all.Like I said,I'm Not an Expert at what they should look like but it does not look like any I have seen demonstrated.I have never used or owned a scope & would not know how to use it if I had one.
SIX-SHOOTER
The Scope Carrier / 100% Modulation sp5it posted looks good to me, like out of a text book. The ARRL Hand Books use to show photo graphs of AM and SSB transmitted signals and such, picture perfect patterns.
Looking at the locals here a few years ago with a scope connected to a receivers IF before the detector circuit I was able to see every ones AM pattern/signal Modulation.
Not all looked good, but did sound good. A few distorted audio transmissions were able to be seen on the scope, but I am sure this is due to the golden screwdriver effect. And the mic gain control seems to get turned up too high.
Some AM Envelope flat topping was seen but still sounded good. They called it "D104 Audio". Listening to your audio and looking on a scope works for me.
Why is it that all the major HF transceiver manufacturers set the AM modulation level so low in their radios?
Is 100% AM modulation not the standard in AM broadcasting?
