B
BOOTY MONSTER
Guest
WB6BYU over at the eham forum said this .......
"If the difference among any such antennas (including a quarter wave ground plane, 5/8 wave, J-pole, A99, or the antenna described here) is measurable, then it is most likely due to high losses in the materials or common mode current flowing on the coax or mast that distorts the pattern:* you can make such antennas WORSE than a standard dipole if they aren't built right, but you can't make them perform any BETTER than one, regardless of the materials and work you put into it."
http://www.eham.net/ehamforum/smf/index.php/topic,75921.msg521877.html#msg521877
my 1/4wgp vs. 5/8wgp results clearly show me there can be big differences !!
and this guy has over 8000 post .
but we all know a high post count does not mean someone is a good source of accurate info . still kind of surprising though .
