Wilson 1000 roof mount
The coil can break in a Wilson, I’ve had that happen several times from hitting tree limbs and such. Since the coil housing is sealed, I had to cut it open with a dremel and fix it. That left it pretty ugly.
Or the coax could have come loose from the 239.
Bobby ,I had an antenna a while back that had one strand of coax shield wire shorting out causing me grief . It was hard for this old man to see w/out his glasses but I found it .:)
    535A has left the room.
  • @ AmericanEagle575:
