Looking for the wiring of a D-104 mic connector for a Midland 13-898B 23 channel SSB Base Station. This radio is not listed in the Astatic Mic Wiring Guide. Any help would be greatly appreciated... Dan
It a four wire, red, black, shield and clear Astatic D-104...Looking for the wiring of a D-104 mic connector for a Midland 13-898B 23 channel SSB Base Station. This radio is not listed in the Astatic Mic Wiring Guide. Any help would be greatly appreciated... Dan
TM86, thank you for the information, this message will self-destruct in 5 seconds... DanBecause it's Sunday and I had nothing better to do...
"Clear" or white wire - pin 1 - Audio
Shield - pin 2 (which is also tied to pin 3 according to the schematic)- Ground
Red - pin 4 - TX
This is a relay switched radio, so the black wire (RX) doesn't appear to be used in this case. If you'd like to connect it somewhere so it's not just floating pin 3 looks like a good spot.
Disclaimer: I don't have a 13-898B or a 4 wire D104 to test this on, so I can't be held responsible if the magic smoke escapes.
Sources:
MIKE WIRING GUIDE
Specializing in unique & hard-to-find CB radio books, plans, kits, modifications, repairs, tech info, & high-performance CB accessories since 1976www.cbcintl.com
That didn't work, I even reversed black and red like they said in an old post. This radio is not listed in Astatic's Mic Wiring Guide... DanTM86, thank you for the information, this message will self-destruct in 5 seconds... Dan
Thanks Captain Kilowatt, my Model 13-898B does not appear in the book you sent either.... Dan (It only goes to 13-888)It depends what wiring book edition you have. It is in this one. Note there are five ways to wire it depending on what the mike base is.
Well, that sucks.That didn't work, I even reversed black and red like they said in an old post. This radio is not listed in Astatic's Mic Wiring Guide... Dan
Thank you Captain, I missed it....
