Workman T225
HeloThunder
Nov 15, 2010
21
44
I was checking out this antenna on palco elec. here is what they post as the specs.
MINI BOOMERANG CB BALCONY ANTENNA. **FREQ. RANGE 27 MHz **MAX POWER 150 W **GAIN 1 db **SWR 1-1.3 **TOTAL LENGTH 122" **COMES WITH BRACKET.
Here are the specs listed on the manf. website for the same antenna.
CB Base Antenna
For Use on Balconies
May be used as a Marine Antenna
1/4 Wave
2dB Gain
300 Watts
Freq Range 27 MHz
50 Ohm
Palco lists the db and the max. input at half of the manufactures specs. What gives?
I tried finding more information about this antenna online, but with no luck. I couldn't even find a decent picture of it. Have any of you seen or used this antenna before, if so, how did it perform? Is it just a knockoff sirio boomerang?
    535A has left the room.
  • @ AmericanEagle575:
