Wouxun KG-UV3D Programing SOS
KK4DCS
Jul 22, 2011
3
New Ham.......Bought a Wouxun KG-UV3D. I am about to pull my hair out. I can program in a channel with the proper off set, T-CTC (PL) and shift + - or off. I save the frequency then when I pull it back up the shift or T-CTC is different. Any Ideas........I have spent a good 10 hr doing this to no avail. Help!!!SOS. I have even looked at all of the utube videos to no avail
Thanks
Thanks
I do have a cable and had loaded stuff to HT but ofter I save it the info I entered such as pl's off set etc.
The wouxon software is really clunky.
Thanks for your time
howdy all == bought the programing cable with my uv-3, finally got it to read the radio, but all I get are write fail when trying to upload freqs.
suggestions?
thanks
kd6lo -- kevin
KG-UV2D
I too bought my radio and cable and when I program it with all the information it says that it has successfully wrote to the radio, but when I ask it to scan my frequencies it goes back to scanning 144.000 to 148.000 and not just what I programmed in.
Get any successful answers yet??
Is it in the 'Mem' mode or 'Freq' mode when you press that scan button?
I don't have a 'UV-3', I have a 'UV-2', but the programming software is the same from Wouxun. 'Clunky'? Maybe, but it works. I find I use the Wouxun program much more often than the 'Commander' software (I have it too).
