Wouxun KG-UVD1P
Burgeogull
New Member
Nov 16, 2013
2
Hi, I'm new to the forum and I have a question for my new Wouxun KG-UVD1P.
First when I turned it I could enter my frequencies ending in zero. I must of touched something because now one I can't enter a zero as the last digit in a frequency, it jumps to a number 7. Also the frequency has a little number 5 at the end of the frequency.
I'm hoping someone can tell me what I have to do be able to enter a zero.
Brian
Don't know the menu number to point you to, but it sounds like you've changed the frequency step.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
