WTB Rohn 25G hinge plate
Status
Not open for further replies.
how high is your tower.. Reason i'm asking is the tilt plate I had twisted and went by by when i tried to pull up 70' of tower and a Ground Plane..
Thanx
Tom
I have used 70' of tower with it the first time I put it up, I used a pulley in a tree up at 40' to pull up the tower, it was a straight pull had no side to side motion on the tower what so ever.
I had guide lines already installed before I puled it up.
Probably be a good idea to have a couple of friends hold those guide lines to make sure the tower does not twist on you.
Also the most important thing is to have a straight pull on the tower. Pull from the center of a tower section so no stress on the joints where two sections combine at.
Status
