confused on why the 400HD draws 100A, while the XM400 draws 85A.
how and why does the XM400 have more output than the 400HD even tho the 400HD has more amp draw..?
i do know you would need a dual final radio to drive the 400hd as to the XM400 lets you drive it with a 148, 29...959 etc........
is this accurate for the XM400:
Power Output (RMS) 400 Watts
Power Output (PEP) 900 Watts
Driven Power (RMS) N/A
Driven Power (PEP) N/A
so if you were to hit it more than should you could see more then 1kw? or is that just for S&G's?
