yaesu 450AT
KJ4WOE
Dec 16, 2010
2
49
ok here's my trouble when im on 17 meters and i tune the antenna with the tuner that is built into the radio i can talk for a min and then the radio will stop modulating and when this happen's the meter look's as if i was holding a dead key. now it only dose this when im using the the built in tuner and only on this band when i use the mfj 949E tuner this dose not happen can anyone tell me what might be going on here.
Wrap an RF choke or ugly balun in your feed line, this should stop any CMC coming back to the rig, also do you have a good ground? I mean station ground is the rig grounded to a ground rod?
I have been chasing the same gremlin on 17 meters also, but little different scenario, I only have issues when I use the yagi, the wire is no problem.
Let us know what you find out when you actually get it eliminated.
