C
Quad...best reason? Dual Polarity...Can't have that with a Yagi...With the quad, you flip a switch for vertical (local talk) then flip the switch to horizontal for DX...
Not all quads have dual polarity tho...Cubex quads are "either or"...Lightnings have both horizontal and vertical, you will need two coax runs to the antenna, and a switch box at your station.
I'm sure eventually I will have to do some repairs on mine, but so far I've had no problems and the antenna has been threw two ice storms, and a couple of thunderstorms that were packing 75-80mph wind gusts...I'm sure first Texas Twister that hit's it, it will be history, but so would any other antenna...
...After saying that I will tell you from experience, in the average suburban back yard at modest height ,it will outperform the same size yagi hands down...
exactly correct, Quads are claimed to both open and close the band when compared to Yagi's at "reasonable" heights.
Another thing with the quads v.s the Moonrakers or maco line is the weight. A Lightning L4 like I have only weighs 22 pounds and has a wind load of 4.2 sq.ft. compared to a Maco Shooting Star that weighs in at 31 pounds and has a surface area wind load of 8.91 sq.ft.Those single loop type quads can be a real PITA to tune for both vert and horz however. Hygain made one with dual loops spaced about 3-4 inches apart and it worked great: no interaction. As for not having dual polarity with yagis, well yes you can if you have crossed yagis like the Moonrakers did or the Maco line. They used a quad reflector element but that is all.The only problem is that all those types, like the quad, have vert and horz. cross arms ro catch the wind and ice. I f I were to go that route I would want something like the Moonraker style because it has about the same wind and ice loading as a quad but no wires to deal with. In fact that IS what I did 35 years ago after a lot of thought and research. Dual polarity is nice but it comes with a price and every location and installation is different.
The Shooting Star also has a 28X power magnification, where the L4 has 30X...(agree tho these numbers maybe allot of hype by the manufacturers)
The quad is also advertised as being a true-wave length antenna compared to the Maco's which I think are 1/2 wave...
The quads do require a little more room in the back yard to get them up in the air and may or may-not require a little moor maintenance over the years with the wires, but if you have a tower that can easily be lowered to do that, then no biggie...My tower is a fold-over type that I can just loosen a few bolts at the base, and hand crank down, then back up with no extra help from anyone...
Price tag on a quad is quite a bit more than the yagi's too which is something to consider, which is why allot of guys would rather home-brew one instead of buying from a manufacture.
Biggest reason I went with the quad tho was the weight, and wind surface rating...By going with the quad I was able to get more antenna, than I would have if going with a yagi, since my tower was only rated for a wind surface area load of about 8 sq. ft. The Shooting Star would have been right at the limit, and you would still need a figure in the weight of the rotor and cables, which would have put it way past the towers rating. ( this is a free-standing tower)
Well - just for local DX, I would take the Yagi anyday. Been running that design for 39 yrs now; no repairs, no problems in all them years.I would like to know your opinion on a yagi or a quad for loacal a dx .
