Yeasu ft 990 deak mic
Copycat32
NNJ32
Feb 9, 2024
47
12
8
64
Northern New Jersey
Hi all.. Question I just Aquired a Yeasu Ft 990 I have a M70 mic that from what I understand needs a separate power source to work dosent do anything not even key up.. but stock Mic works fine.
Question is what model mic would work on its own.. Any suggestions? Comments?
Thank You
The radio does not have power at the mic jack. So, yeah, you need to provide power somehow. I don't know that mic model, but if the PTT line is wired correctly, the radio should TX.
When I had a 990, I isolated one of the two ground pins and applied voltage to feed the MD-100 I had, so I didn't need the Rube Goldberg wired workaround that Yaesu put out the bulletin on.
Thank Yo
Reactions: Copycat32
I was. Looking at that ext power setup didn't care for it.. Was considerin wireing an Astatic 878dm to it like I did my ranger AR3500 but After a little more research I found on yeasu the the MD-1C8 mic was designed for that and a couple other radios that would have needed then external supply... I found one and ordeted it hopefully it works with out a hitch then I'll sell the M70 that I purchased from Japan brand new....
If this doesn't work I'll try what you did with the ground pin..
Thank You
