I will keep my Siltronix 1011d...I have had 257 and galaxy radios...but the old silly cant be beat...turn it on and leave it on they dont drift... 73s de JW
Can someone let me know if their ACTUAL SMeter on their rig moves while transmitting in either the LBS or USB SSB mode? Mine moves in the AM and FM modes, but doesnt budge in SSB, The only reading I get in SSB mode is the lighted meter below the frequency display.
Thanks
Precisely. That's what my S45HP does (actually a bit more). You can't measure PEP on FM as there is no peak power.20 watts FM is all it will do.
If you need more; add amp . . .
Make sure you have no common mode currents flowing back down the coax.
Funny, my HR2510 doesn't suffer any of those problems.
Not an issue. I sometimes run an amp and so long as the input impedance is close to 50 ohms, there should not be a problem. Make sure that your antenna is properly grounded, and has a very low VSWR. Avoid RF ground loops as much as possible. This is true for any mobile installation. For base operation, the same holds true. Low VSWR, avoid reactances, and avoid common mode currents.I have a RF choke from coax next to the antenna so hopefully this should stop it. However, I would be worried about using my amplifier with this radio if its that sensitive to these return currents.
avoid reactances,
The use of an antenna tuner will get rid of extraneous reactances.how exactly do you avoid reactance on an antenna unless you only use it on one frequency?
the further you move from center frequency the more reactance will play a part, as most people in the uk operate from low on 26 mhz (or some from 26.965) to nearly 28 mhz (uk legal cb band) avoiding reactance is nigh on impossible.
Will too many turns of coax in a choke cause adverse effects at 27 mhz?the old faithful ATU,lol, is there anything hams can't sort out with an atu? lol
surely its better to cure the real problems than use an atu to plaster over deficiencies?
my experience of people using rf chokes on 11m generally finds them using one of the wrong number of turns (usually to many turns) for efficiency on 11m because they copied something they read on hamuniverse that states the coax wound rf choke is suitable from 80m or thereabouts to 10m which is total bullshit.
ofcourse the first hurdle you need to surmount is the shit build quality on magnum radios compared to others. they really need to start paying those 10 year old chinese kids some decent wages if they want them to produce decent quality.
Agree 100%. Which is what I try to do here. My friend, not having an appropriate current balun, decided to follow Hy-Gian's instructions and wind his own. Those coax wound baluns vary widely in quality and perfection. His has some weird anomalies. I avoided all that nonsense by simply buying a new, proper current balun designed for yagis. The original Hy-Gain BN86 balun is a voltage balun, and subject to imnbalances as is my friend's coax balun.[...] surely its better to cure the real problems than use an atu to plaster over deficiencies?
Often true for hams as wellmy experience of people using rf chokes on 11m generally finds them using one of the wrong number of turns (usually to many turns) for efficiency on 11m because they copied something they read on hamuniverse that states the coax wound rf choke is suitable from 80m or thereabouts to 10m which is total bullshit.
La-dee-dee, sorry, what did you say? No shit!ofcourse the first hurdle you need to surmount is the shit build quality on magnum radios compared to others. they really need to start paying those 10 year old chinese kids some decent wages if they want them to produce decent quality.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
