good luck on the consensus ! LOL
You're quick, boy, real quick
Man we have been having fun with King`s thread....
Really tho, if you got the stuff and like to play with antennas....go for it.
I have loaded up some off the wall things just because i felt like it, antenna tuners are an experimenters plaything for me, and like someone else said, you would be surprised what will work.
It will not have any gain, but it will most likely put a signal on the air, i bet it will have a ton of rf flowing on the outside of coax as already said.
But even coax at 30 or 40 feet is a signal in the air.
Post up the test results Homer, we will all be watching this one.
( never know, might be a good seller on e bay)
With the right size hay bale (large round) you hook up to the baling wire and you got yourself a quad!
Captain K, you are all hung up on theory, I was using a antron 99 on the base, the top section was a fiberglass whip that had been broken in half and I filed the end down and screwed it on the top, never could get the SWRS down below 3 but it talked great, But now I am using a walmart mag mount stuck in the center of a 3 foot snow dish and it rocks!!
I get 6 to 12 Lbs gain with my snow dish over the Antron, you guys can sit here and spout theory all day but until you get a $18 dollar mag mount and stick it on a snow dish you will never learn that book smarts is old school and REAL WORLD testing will blow theory out of the water..EVERYTIME >>>>>.and i just got DOWn!!
:blink: :blink: :blink:
i was kidding.
really.....
I was just giving CK a bad time.
Besides snow dishes are made out of Aluminum, or plastic, and i can not find any glue that will keep it held down as I slide down the hill on my as....
..........which also doesn't make sense considering antennas radiate from the upper portion primarily
it could work, if you have a variable 48-72 inch chamber baler, you would need ah lets see 17.2083/pi or a 65-66" bale! good ole prairie grass, i have a market for the alfalfa!
:headbang
that calc is for a half wave, i can't make a 132" bale for the full wave!
sheesh
The output is similar to my magnetic loop antenna. Lots of magnet energy and not so much in the way of watts.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
