power supply
dave69
Sep 19, 2009
27
3
13
i am looking for a new power supply but i am wondering what is better,switching or transformer type for the same output power 30amps.!! i have noticed price is not that much apart from the two at least from the ones i looked at eg. samlex jetstream mfj pyramind, anyone know any diff. on what is more reliable and lasts longer
ok thanks guys i guess i may go with the switching type,wish me luck on the longevity of this type of supply!! I thank you for your voices on this matter.
My experience is the the switchers can be less expensive for the same capacity, but you have to watch out for the cheap ones. Go with a name brand like Astron, Alinco, etc., and you have better chances.
I've had an Astron SS-25M for several years, and am very happy with it. I would buy another Astron when I'm in the market. I have been thinking about their 30 amp version, the SS-30M. For about $150 retail it seems like a good deal.
Dave_W6DPS
Dave_W6DPS
Go with astron,diamond,any of the name brand...not phase three...they are known to go 2 trimes voltage when they go out and send 24 volts into whatever you are running...73 JW
Consider the Diamond GZV4000 switcher.
Takes 40 amp peaks and 30 continious.
Has a lighted meter to see either voltage or current.
Voltage out is adjustable 5 to 15 volts.
Front panel 6 amp terminals and car type 10 amp outlet for utility uses and rear binding posts for high current application..
Fan cooled.
Instant shutdown on a short without big current draw.
The rateing for continious use is 15v X 30a = 450 watts DC.
Peak is 15 x 40 = 600 watts.
Fan cooled.
DLS-55 IOTA which can be turned up to 15vdc easily and the IOTA is $15 less on egay.
SPECIFICATIONS
DC Output Voltage (No Load) approx. 13.6V (DC)
Output Voltage Tolerance (No Load) + or - .7%
Output Amperage, Max Continuous 55 Amps
Output Voltage (Full Load) approx. >13.4V (DC)
Maximum Power Output, Continuous 750 Watts
Ripple and Noise <50 mV rms
Input Voltage Range 108-132V (AC)
Input Voltage Frequency 47-63
Maximum AC Current @ 108VAC 13.4 Amps
Typical Efficiency >80%
Max Inrush Current, Single Cycle 30 Amps
Short Circuit Protection Yes
Overload Protection >100%
Line Regulation 100 mV rms
Load Regulation <1.5%
Fan Control Proportional
Thermal Protection YES
Working Temperature Range 0° - 40°C
Storage Temperature -20° to 80°C
Withstand Voltage (VDC)* 1700/1700/500
Dimensions 9.7" x 6.7" x 3.4"
Weight 5.0 lbs
GZV4000 Switching Mode DC Power Supply
Special Features:
• Size: 8.25" x 4.5" x 13"
• Weight: 8 lbs.
• 40 Amp Continuous Rating, 100% Duty Cycle
• Variable Voltage Control 5-15 VDC
• Voltage Control Knob has center detent at 13.5 VDC
• Overload & short-circuit protection with Current Foldback at approximately 42 Amp
• Over Temperature Protection; variable speed fan automatically controlled for quiet operation
• Meter Selector allows monitoring of voltage & current
• Access to front panel DC terminals and cigarette lighter jack; standard 40A terminals on rear panel
• Built-in 8W speaker
• Circuitry yields high RFI protection from external sources
• AC line filter for EMI protection
• Standard 3-wire heavy duty line cord
• Power Indicator & Overload Indicator
• Accepts 120 VAC ± 20% 50-60 cps (Not compatible with 220V)
• Ripple & Noise less than 8 mV r.m.s.
• 1 Year Limited Warranty
