question if i might?
looking at the above drawing for the GM...so if running something with a coax choke already incorporated into the design of the antenna, would adding one to the coax be redundant? i'm about to lift my 2012 and i believe it follows the same design element
thanx
Hi Marconi, just tried a coax choke/Ugly balun coil with thiner coax on a 6cm (slighly less than on the plans) former and it comes close to your coil legnth and the 331.5cm coax run given on the plans so it is mm that are the diamensions given, rain has stopped play here "again" going to try the full sized 16 turn coax balun once a former of the right outer diameter is found and also do it in one run of coax from the swr meter up to the bobtail 1/4 wave 50 ohm shunt which will be on a T piece for easy changing while experimenting as I am sick of soldering, this must be possible with cheaper coax for lower power use.PhilipB, how can the length of the coil former added in at the bottom of the image above be 331,5 mm tall?
Go HERE and scroll to RG303 and you'll find it's 29.4pf per foot.
9cm is 3.54"
3.54" ÷ a foot(12") = .295 feet
.295 x 29.4 = 8.67pf, not 15pf
What am I missing?
Hey Whiplash, just had a look at a 2012 out of curiosity and it looks like an enclosed RF tuning coil at the base not an ugly balun as they are called? others on here may have better idea, but if you have problems with tvi I would give it go it worked well for me with only 5 coax turns on a 9cm former.
Phil
If homebrewing a GM, is there really a need to use the same type of RF choke, surely a torroid type choke would perform the function much better, and with a higher choking impedance?
As for the Vector 4000, I'm sure the debate will continue, opposing currents tend to cancel each other out, what is it about the cone on the Vector 4000 that goes against this accepted theory?
If we are discussing homebrewing a GM, and the complexities of the choke and what it may or may not be doing, then adding a torroidal choke would not only simplify construction, but be an effective choke to boot, I'm not questioning the Sirio version
As for modelling, I have every faith in a well designed model, anything you've got would be of interest.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
