Amplifier purchase help
i was not dissing the dave made name. just the guy selling it for so much money for a half built davemade
If it's base, go with a tube amp for a cleaner signal. If it's mobile, go with Texas Star or RM Italy since they have bias and will sound good on SSB. Most of the "aftermarket" amps like Xforce and Dave made are not linears, they are just class C amplifiers and sound somewhat lousy on SSB as a result.
What about BM Technology AB biased amps with thermal tracking?
Best bet is to get a basket case SB-220 cheap. Long as the transformers are good send it out for a CB "work up" buy a pro. As BBI shows they do 2KW plus when done right.
Step up and buy the last amp you will ever need. Ameritron. http://www.ameritron.com/
You will sound good and you will have good quality, not the class "C" hacked crap.
Thanks for advice.
The 500s at $800 or so AND the 80A draw is a whole other world from where I now sit.
But at least it’s the right path for the eventual home base HF rig.
Got sidetracked on eHam (happens a lot) and was reading about Hy-Gain antennas. Whammo #2.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
