https://www.rchelicopterfun.com/dps-600pb-build.htmlHP DPS600PB
YMMVNew Ok looking for a good power supply that gives 40amps steady to run my dx98vhp.Any suggestions
We know that, but which ones? How to boost voltage to 13+ ?New A simple 30 sec solder job and your done (just solder two taps Together)
The powermax 55 has a good price but are the adjustable.Also the megawatt looks good toCheck out .......
powermaxconverters.com
Have the PM3-LK, a PM3 will do the same. Quality without The big price. You can call them and discuss your needs, if they are open. This crap going on has shut down everything. You can find those same converters on Amazon for a good price. They are also able to be run continues voltage of desired setting.
USA made out of Florida.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
