YouTube - 3CX10.000A7 OUTPUT TEST
YouTube - My new 3CX10,0000A7
3CX10,000A7
THIS IS A 3CX10,000A7 CONSOLE UNIT. Output power 5000+ watts maximum 450 watts bird and 1000 peak will give you 15Kw+ peak output Tube - 3CX10,000 test full power output Transmit/Receive switching 60 + Amps open Vacuum relay Power-line requirements 200/240 Vac 50/60 HZ 50+ or - Amps at 240 Vac Power Supply Heavy duty 3.5 peak amp steel core transformer and high capacitance grade filter capacitor, also features time delay starting to protect the tube from over current load. "Soft Start-
3CX10,000A7
