AO-27
Qwazyone
294
7
South of Canada, North of Mexico
I know W1MED has worked AO-27, but this sat has a timing sequence of off/on/analog/digital. The schedule is posted at www.ao27.org and at the bottom of the page there is a link to a website with a computer program that will figure out when each event occurs(on/off/dig/ana) AO-27 Satellite Scheduler
Has anyone else used this? The info from the program matches what the webpage indicates for the next event which for now is dig at 11:57:52 UTC
Thanks for the link to the calculator. I wasn't aware that they had that, so it will definitely make it easier to make contacts on that bird.
I have actually had the thing change modes while I was working it, kind of odd to all of a sudden get packet bursts ..
For some reason I think I have only heard AO-27 on the south-north passes(ascending passes?, been too long since I took the tests). Maybe with having next week off, I'll get a chance on A0-27 and I think that AO-51 will be back on V/U mode.
W1MED, I did notice those packet bursts would occur at about the same position in the sky and then I found the info on amsat and the different modes
moleculo, glad you like it, hope to make contact at some time on one of the birds
Does anyone know of a reasonably priced 2.4 GHz receiver for Ao-51 V/S mode
    AKA- UDX122
