BIG truck antenna mount/install LOCATION ???
number 9
Jun 29, 2018
5
4
13
56
Yes , i did a search. everywhere. iv yet to find a decent location for an 11 meter 27 MHz sirio 89" steel whip on Paccar trucks (Pete/KW) steel dump body. i had a Mack where i fabricated a 6x6" steel plate / Wilson5k mag mount on the battery box. that had excellent 1:1 ratio. the problem now is the lower mirror bar height. batt box idea wont do in this app.
thinking about a side dump body mount now . The body measures 17'6" . so that means atleast {45} 50' of coax to reach the interior cab console. ground plane ? bonding ? grounding ?
any ideas or chimes are greatly appreciated !
A picture or three will help. What model truck?
(I’ve had a difficult time after logging in, almost can’t post it’s impossibly slow, otherwise I’d have answered earlier. Seems I’m the only truck driver around . . not).
1). What height restrictions do you face?
With a T680 + 53’ van I run cophase to 14’ while OTR. Getting them above the trailer is a real help. Aftermarket mirror mounts.
2). Gear all sounds good. I think it’s “the picture” that we are missing in order to visualize.
Apologize this thread got missed. Welcome to WWDX!
Like Slowmover requested, a pic would be great assistance. This may be urban legend, but I had more than old CB tech tell me when everything else fails on the big dumps, mount a 102 inch whip and spring on drivers side from bumper corner. He had also mentioned using 21 feet of coax. It would be mounted like a corner marker. I have come across big dumps with setups like this in the past. I know I am not discussing your Siro. but if all else fails, I hope this idea may help.
I always mount on the drivers side. Less trees to rip it off the truck. I tip the antenna down a bit so it is tipped further forward for even more clearance.
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
