I have a 150 cobradx that the audio is acting as if the limiter is killing the audio.you can start to talk and the audio drops off to vertually nothing and the needle kicks back as if the limiter is kicking in to hard,did the bulletin from cobra for this and also noticed before the mod and after the hi and low audio pots do not change at all.I contacted cobra and they had no idea and I have read here were DTB is doing some audio improvements to the radio,wondering if any one here has had a like problem.also did a complete alignment before the audio mod and its as should be.the person that owns the radio bought it and had it modded for 11 meter on the road.he is a truck driver.the limiter is in tact.also working.
thanks for any ideas.
Sonoma
Sonoma
