Connex 3300 - No RX Audio
Chris Lawrence
83
40
[edit] Resolved below ⬇️
RX works
RX audio does not work
The actual volume control pot is working properly adjusting between 0-50kohm approx
Tx works
Tx audio (modulation and talkback) work
PA Audio works when talking in mic
What can I provide you with to help fix the issue.
I can hear a pop when turning on power.
Meet the two solder pads that should have been soldered together. Held together by a flake at one time.
Reactions: Handy Andy
I've also seen that more than once before myself. I take it that fixed your issue?
Yes. It was strange because the voltage on the the trace on the board that comes from the “switched” leg of that control pot was showing 2.7v. My first thought was a shorted component was drawing down the power. The radio would actually turn on, but dim. Thats wierd.
    AKA- UDX122
