drive my eagle 500 amp
211 in tha mag
411
3
Is this the Kengrich Eagle 500 Base amp? it is Brown Woodgrain looking box? If so, you dont need to put anything over a dual final radio into that amp, and about a 2 watt dead key.
</p>
hi guys
my question is this .... I have a couple of mobile linear amps...one is a 75 watt one is a 150....if i use one of these to drive my eagle 500 instead of just the 18 watts my golden eagle mark 4 puts out...will i see a signifant difference....or might i fry something..
73's
cobra
</p>
I have owned 7 Kenrich amps over the years and they are telling you the gospel.Dont overdrive that amp.Like was said above if you want more power buy a bigger amp.Take care.
2TX922
IR2622
CDX922
WO922
YG22
LS22
DX22
MM22
LW22
</p>
I Know this is an old thrread but...
I have a Kenrich 500 now and am looking for any info about it like schematic or service manual i can find. All I have found so far is a fuzzy schematic off cbtricks site.
Thanks for the help
Thanks for the help
Go to CBtricks.com and look in the amp section. You will find what you are looking for.
drewbOy, maybe husker did not see you had all ready been to cbtricks website, though he quoted your post. Ask him to lend you his "fuzzy viewer screen protecter", then maybe you can see it. Good luck.............
Fuzzy? I worked with schematics way worse than this one. Just click on the "+" button on the PDF toolbar to zoom in and you should be able to find anything you need. It used to be rough when you had a xeroxed copy of a xeroxed copy of a...........
BC
That box was built before dual final exports were around. I would not even run a dual final into it if it has driver tubes. I was made to run with a cb and it is old. I never owned one but had a scout and fried the tubes with a dual final radio years ago. Like others said if wanting more power get a bigger box.
