EZ Up 40 Pole or ROHN 5' sections to get 25-30'
CB590
W9WDX Member
Jun 29, 2016
1,545
1,263
173
Trenton Nj
www.590dx.com
Debating on the EZ Up Pole that is 18ga sections with 16ga top section for $153 shipped. Or ROHN 5' sections that are 16ga for $121 shipped for 5??
I currently have 2 top rail sections (17ga or so) with 4 (3 shown in pic with one down lower) of the 4" wall brackets and a coupling holding it together to my outside wall.
The top most 10' has about 9' above the top 4" bracket. And I can't really get a bracket on that second eve as shown in the pic. I might be able to use the old telco eye bolt up near the second eve for a couple black zip ties.
New antenna is the Sirio 2016 weight of about 11# and the old antenna is A99 weight of 4-5# or so.
New antenna has some radials so I was thinking an extra 5' of height.
Other option is to slide a piece of top rail in at bottom and raise it by 3-4 ft that way. So coupler is not disturbed either.
Reactions: 357magnum
Put a peace of angel on the top pipe to help hple it just drill a few holes in it use a u bolt at the pipe end.
Oh. That may work. But I don't have a 10/20' ladder. Only a 6'. Hence the fun.
I had to plant the top 10' and antenna as one unit into the bottom 10' section. Fun fun.
and should I just slide a 3-5' top rail under the whole thing and just re-clamp? Or get a whole new mast??
You can add guide wires and go a lot higher . If you wear hear in eastern N.C. i would lone you a 40 ft Later and you coud look around
Reactions: 357magnum and CB590
Rent a 20' ladder?
