FTM-350 firmware and extend TX mod
depark
Feb 17, 2010
222
16
Kelowna, BC
I have questions about the firmware updates and the extended TX modification. Should I do the extended TX mod before or after I do the firmware updates? Do I need to install firmware update 1.1 and then 1.2 or will just installing 1.2 cover all the changes? :confused: Thanks in advance.
The latest firmware is inclusive of all previous fixes, so just install the last one. For the mod, it's not going to matter when you do it, it will work.
V1.3
I see that there is now a version 1.3 available. Anybody know what improvements are in this version?
* Version 1.3 (2010-Dec)
(1)Correction of the SORT FILTER function
In the previous software, there was a problem that the radio did not work correctly under some SORT FILTER function setting and condition.
This problem has been resolved in this firmware.
