Galaxy 33hp2
MNTSIDE
Jan 31, 2021
36
7
18
59
Good evening
Looking for a little help on this galaxy
It’s a 33hp2
Right now I have good carrier on all power settings, modulation on high and medium,
No modulation on low
Anyone know where to start looking to correct this
Also have no meter response
Thanks for you help
Kevin
At least we know that the modulation limiter is working on this radio. There are two AMC (Automatic Modulation Control) trimmer pots that set the max AM modulation level. One for low, one for medium and high.
The limiter trimpot for Low carrier is VR12. Pretty sure this one is set wrong. When it's turned far enough, it will limit the mike audio to zero.
Medium and high side AMC both use the same trimmer pot VR14, looks like.
  • @ ShadowDelaware:
    No conditions woodstown NJ.
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
