Galaxy 88 Part needed!
thedirtmover
109
2
26
I need an old style freq. counter module for an old Galaxy 88. Ive seen these in Old Galaxy IIs, some Old Couriers, some old Nortstars etc. Its the big one I need to light the common cathode LEDs.
You might be able to fix the counter as mostly all had the same problem. Diode D603 (2.4v .5 watt zener) overheating. Normally just replacing it with a larger 1-watt version would do the trick.
http://www.cbtricks.com/radios/galaxy/dx88hl/dx88hl_freq_pcb_old.htm
All I get is a single 0. I did change the diode and I also thought 10 volt blues. None of the above fixed it. I was kind of afraid that the Chip was blown.
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
