Galaxy DX44V VFO Windup?
Only works on a radio that came with a "Delta Tune" or clarifier. This is the circuit function that provides the "slide" when you repurpose it for transmit instead of receive.
In theory, you should be able to add enough parts to a DX44 to do this. Just compare the PLL's crystal circuit in the DX44V to the diagram for the DX55V. Making the 14.01 MHz crystal's oscillator circuit look like the DX55V would only be the starting point.
As someone once said "Just because you can doesn't always mean you should".
Reactions: walterjn
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
