Ham International Jumbo Mk1
JC_enfield
Sep 17, 2009
21
4
13
Does anyone have or know where i can get a good allignment document/service doc for the HaM International Jumbo?
Ive got one which needs the audio looking at and also is 3Khz off frequency
i found a document on CB trix but to be honest wasnt too much good.
Thanks
The board the the Jumbo has is a Cybernet PTBM058 or PTBM059
The service manual gives all the information you need to know,If you're unsure how to use the information or do not have the proper test equiptment I suggest sending it to the rig doctor.
  • ham_international_jumbo_om.pdf
Thanks IMD262 but thats for the Jumbo 3 and I need documents etc on the Mk1 as the board is different
The jumbo 3 has the Cybernet PTBM133A4X
The jumbo I have uses the Cybernet PTBM059COX which I am lead to believe is the same board etc as the Ham International Multimode II
now I have this Ham International Jumbo
I had used that service guide last night but its not very clear when it comes to setting the LSB and USB offset oscilators. I can obtaine the correct frequency on TP4 with the band selector set to low but it wont change when put on MiD or High
I have a Jumbo here on my desk. Its a nice radio , the only thing wrong with mine is one of my lights behind one meter is out. I get good reports on modulation with a power mike .
I have a jumbo mk1 some screwdriver jocky has been inside it and messed up all the wiring can anyone help with a wiring diagram.
Many thanks in advance
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
