I am trying to understand this. I would like to have 6khz up and 6khz down with the center being right in the middle.
I found this online
1. Find D52, R44 and R174 and remove them.
2. Solder a jumper from where you removed R174
3. Follow the WHITE WIRE from the clarifier control to where it attatches to the PC board and UNSOLDER it.
4. Resolder this WHITE WIRE to the PC board ground.
5. Follow the ORANGE WIRE from the clarifier control to where it attatches to the PC board and UNSOLDER it.
6. Resolder this ORANGE WIRE to pin 3 of MB3756 Regulator.
you should slide about 4Khz down and 1Khz up.
If you do the changes below you will get -6khz to +6hhz with 0 right in the middle. The Tx will track exactly with the Rx
1. Jumper R175
2. Jumper D51
3. Remove R149
4. Remove R188
5. Remove R44
6. remove wire form the high side (+ or full clockwise pos) of the clarifier
7. conncect pin3 of the IC4 to the high side of the clarifier
8- Replace R174 with a 3.3k resistor
9. Attach a 12k resistor from the jumper of D51 to pin 3 of IC4
So I have some questions here
First is the second set of instructions an add on to the first instructions or is the second a replacement for the first instructions? At first I thought it was its own stand alone instructions but the second one does not require doing anything to D52 and would also only be changing one wire on the knob.
Also in regards to step 6 my knob colors are orange blue white. I am pretty sure that the white is what is considered the high side but I want to make sure.
Any help would be greatly appreciated.
I found this online
1. Jumper R175
2. Jumper D51
3. Remove R149
4. Remove R188
5. Remove R44
