Help with name brand
Stump31
Mar 13, 2008
12
NJ & Florida
Does anyone know anything about Skullkracker amps or Snowcap Technology amps? Are they any good? Or should I stick with names like Fat Boy or X-force? :headbang
IMO, Skullcracka amps are top of the line class "C" amps. They out-class the other amps you mentioned. They are/were made by "Prime Minister" aka "Sir-Mix-Alot" aka Anthony Ray. Not sure if he's making them anymore.
you dont wanna buy a skull amp unless you can volt it .they are made for high volts and you wont see the numbers unless you can volt it .
its more of a comp amp.
now fatboy/xforce/davemade and the like are your standard swing amps and dont require volting.
you cant buy a skull amp new anyway unless you know someone.
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
