Shadetree Mechanic
Delaware Base Station 808
Here is the current info that I just dug up. Basically what I had in my notes with info on the AM modulation transformer. As was said earlier, the modulation transformer in these radios is barely adequate to run the radio in its stock form. There is a limit to the amount of lows you can add before excessive heating of the transformer becomes a problem. If the radio has increased audio, expect the audio chip to get hot as well as the regulator. I usually leave the transmit audio alone and boost the audio chips gain. I also leave the Finals alone save for a swing kit and run an Astatic 636. Enough lows, but not more than the radio can handle. I am not worried about power because I run amplifiers. The receive I will open up to the full Goldfinger values and run a speaker from a bookshelf stereo system.
Use at your own risk.
https://www.wwpdx.com/ForumWWPDX/viewtopic.php?f=117&t=13845&sid=c7ea547054d6f6001c1be8995c3a43ea
