I'm making a T2 LT dipole and then going to convert it to a 3el vertical Skypper beam.
Stay tunned
First a t2tlt dipole can be easily mounted Vertical or Horizontal as the coax comes out one end Unlike conventional dipoles It uses part of the coax braid its self as half your ant and the center conductor ( or additional wire )as the other half It is most likely the simplest antenna you can make.It can be made completely out of coax, or as I have done ( to save some coax) 8 ft 6 inches of electrical wire and coax.
Stay tunned
