HR 2510/Hang-up problem....
M
MrOct2527
Guest
I have an 2510 that I recently got. I like this radio very much,...But after keying and talking I might add, it lock's up on me...?(Won't Un-key, not Mike prob, does w/ all tried!, Thougt maybe coax but all other radio's work Fine ?) Please Help! ,...as I want this Radio 2 Be top-shelf ! Thank's , and 73's !
</p>
</p>
Solution:
Try this...
On the underside of the main PCB, You will see 2 Disc capacitors soldered across the Final . These are the 34Mhz Pull Off caps.
They are know to cause the radio to Oscillate.("Weird Dead Key Problem" - See references to Yaesu Tom) To 'Cure' this, unsolder one side of the Disc Capacitors and Bend it away from the PCB.
Roger
</p>
Solution:
Try this...
Roger
</p>
Hello,
Thanks for the Flowers!
Glad to know what I do is appreciated.
Af far as the caps.. I would only remove them if there is an issue.
The Manuf. engineered them there for a valid reason, and they normally do what they were desinged to, but in some instances, they need to be removed.
(I dont think it would harm the radio or degrade the performance if they were removed.)
Roger
</p>
Hello,
Roger
</p>
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D">
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/glasses.gif ALT="8)">
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
Glad to here it!!
Roger
</p>
Glad to here it!!
Roger
</p>
  • @ ShadowDelaware:
    AKA- UDX122
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
