M
Metal Head
Guest
Ok, I jumped in head first. Some of this I understand and most I do not. I did figured out the standing wave part which is the main reason I got it. I unhooked my box and took a reading from the coax after the box to the ant. On channel 40 27.405mhz I have a 1.0 SWR (I didn't know that was possible), on channel 20 27.205mhz I have 1.2. On channel 1 26.965mhz, I have 1.4. I'm useing a 102" whip with a 4" spring with 50 OHM RG8/U coax. So I'm guessing this is ok.
The digital meter reads 1.2 SWR and the analog reads 1.4 SWR. What's up with that? :?
