Check Grampa broadcasting at 9:00 minutes into the video below on his Gain Master.
wish we could have heard that starduster and gainmaster switch between,,, that would have been a nice data point to go along with the rest of your data.
I allways enjoyed 4040 videos ..sure miss his style of radio
Gamegetter, I just noticed on Scott's video he had the date as a header. I checked my old notes to see what I was doing around that time...and I notice in the few days earlier I was working the following.
Scotts video shows the date of the recording was Jan 8, 2011. On Jan 2, 2011, I had my A99 up and working. On Jan 6, I had my I-10K up and working. On Jan 7, the day before the video I had my old Top One (AstroPlane) up and working.
I remember I caught up with Scott again to do the video above 2 to 3 days later. So on the video that failed I was either working my A99, which I'm inclined to think was the case...or I was working either the I-10K or the Top One.
Below are the three Signal Reports I made around that time...and according to the results...it wouldn't surprise me if anyone probably would have shown me similar results. In the video I think I only mentioned the Gain Master, and did not mention the other antenna that we attempted to compare earlier...the video that failed.
So, I can only guess what really happened.
I miss the old man, doing his thing too. He must have been ill for a while. He was too young to die.
GG, that time as just at that particular time, my GM was basically one of my quietest vertical antennas.It is coincidental you mention the GM is noisier if i interpret your siganl report correctly, as i mentioned the other day, i thought the super maggie was a bit quieter than the GM.
I also had good contacts working my AstroPlane, an old Coppers Electronics Top One. I often did try and get the top as high as some others I happened to have up at times.If you remember we discussed that top one(astro plane) design before and that is what got me interested in this because i always felt the astro plane worked as well if not better than other 1/2 wave or 5/8 antennas. I'll catch some heat for that but, it's just my opinion.
I'll look for a model already posted and give you a link. Then I'll look for a newer model. I just did an A/P, Imax and Sirio Vector...for a recent WWDX thread where DB described his thoughts on these 3 antennas.Di you or anyone else ever model the astro plane?
