A transistor, or tube, can't tell the difference between just a carrier, or carrier plus modulation. It only knows if the applied signal is less than too much or too much. If it's less than too much then that transistor/tube will amplify it. If it's too much then that transistor/tube will quit/die. It's that simple, and the user of that transistor/tube is supposed to know the limits, how much 'too much' is. The user can go to the time/trouble of finding out what that 'too much' is, or he can take the manufacturer's word for it since the manufacturer has already done that. The manufacturer always includes a 'safety factor' in there statements about how much that 'too much' is, and that's a pretty nice thing to do. It saves the user from the expen$e of finding out for themselves.
Then you get into the part about a transistor won't handle as much power using AM mode as compared to SSB mode. The differences there are in what the signal consists of and how you do that measuring. SSB has no carrier, it's all 'modulation'. It's also typically measured in 'Pep' watts rather than 'Avg' watts. SSB is an 'all or nothing' type thingy, no 'constant' input, it's always varying (unless you input a constant tone). If you do use a constant tone for measuring, and use 'Avg' power instead of 'Pep' power to do that measuring, you'll find that the limit for that transistor is the same as for AM mode. That "limit" for the transistor or tube doesn't change. But how you go about measuring that limit certainly can make a difference in the results.
